[FOR SALE] 1974 DART CUSTOM
66durgederp
"pull hard, itll come easy"
Zoo montana
Rating - 0%
0   0   0
I have a battle tank of a dart for sale. Montana car pretty much its entire life shes seen some action. First off, yes, the body is crusty. The subframes appear to be solid. no obvious damage or rust. Leaks coolant like a sieve from the timing cover where it meets the block, upper passengers side. radiator had some backwoods attempted solder repairs done to it too, but its fixable. It is the 26" core. The good? Its a factory V8 car with power steering, power brakes, and A/C. It has 10' discs up front and a peg-leg 2.94:1 8.25 and it is the 5x4.5 bolt pattern. Comes with some crusty rallye wheels, and an original "tuff" wheel with the correct column adapter. I rebuilt the carburetor, installed a new fuel pump, wires, brain box, and a phased distributor (by me) She runs, stops, and makes angry V8 muricuh noises. Highly recommend trailering it, but if youre a glutton for punishment, do what youd like. Clean montana title in hand ready to go.
If youd like a winter bomber - here you go! You need that awesome V8 spool mount k-member and big bolt pattern suspension swap? here you go!!! asking $1000 obo. located in missoula MT. Thanks.
