1974 Dart Street Strip Build
CS1121
Peoria az
Hey everyone, my names CJ. I’ve been around cars for awhile, got a Dart from a customer of mine. 1974 318 car, disk brakes, swinger model. I am making it a street strip car. Have some friends helping me that are good fabricators and builders so it helps a lot.
Engine is a 70’s 440 with a forged crank. Engine builder is machining and assembling it, should have it back in the next couple months.
Engine-
Forged pistons
H beah rods
Indy EZ-1 heads
Bullet Hyd roller 23x/24x 110lsa
Indy dual plane intake
AED 850 carb
NOS cheater kit w/ progressive controller
MSD ignition
Transmission-
Tci 727
Hughes 3000 stall
Rear end
Ford 9”
Strange S trac
3.89’s
1350 joint
Chassis/Suspension/ Wheels
Subframe connectors
Torque boxes
8.50 chromoly cage
Mini tubs
TRZ chromoly column
Control freak 4 link
Weld Aluma 15x10
Weld Ventura 17x5
Manual steering box
Parachute
Rhodes fuel cell w/ 450 pump
Going to rebuild the front end with a good shock.
I’ll keep posting all of the updates on here, hoping it will be a fun car. Not a lot of people like these later years but I’m hoping we can make it cool!
Ended up getting a 512” stroker kit and dropped it off at the engine builder. It’s from 440 source
Just got the car back and going to start seam sealing and painting everything.
Welcome from the Tucson area! Nice job so far, looking forward to seeing the finished product -- and maybe a video or two...
Got the entire underside of the car painted and the wheel tubs undercoated. painted the rear end and installed the brakes, and got it back on the ground.
im starting on the front next, do you guys think welding up the stock K member is beneficial or is it unnecessary? figured it was a good route to go but didn't want to go through the trouble if its a waste of time.
