Dart/Valiant
Active Member
Clean metal, the right size wire and settings, and above all else, practice, practice, practice (did I say practice) on some scrap sheet metal the same thickness as the replacement pans.
Then either order you a patch panel or make one. Or replace the whole floor if you want a factory like install
Thanks, but what can be the right size wire or rod and settings? The replacement pan is 19 ga steel. When removing the old rusty metal, do you keep a narrow edge of the old floor on the sides?
