[SOLD] 1974 Duster bracket car roller
physixx
Edison, NJ
I HAVE FOR SALE, A VERY STRAIGHT 1974 DUSTER BRACKET CAR. IT IS PAINTED RED WITH BLACK ENGINE BAY AND INTERIOR. IT’S A ROLLER, SET UP FOR A SMALL BLOCK AND HAS THE FOLLOWING:
CLEAN NJ TITLE
8 ¾ REAR WITH THE 742 CENTER SECTION
NEW 35 SPLINE AXLES, GREEN BEARINGS AND 3” STUDS
NEW 35 SPLINE LIGHTWEIGHT SPOOL AND BEARINGS
NEW 7290 COARSE SPLINE PINION YOKE WITH NEW MOROSO U-JOINT GIRDLE #85820
NEW REAR WELD PRO-STAR 15X10” WHEELS AND NEW LUG NUTS
REMANUFACTURED FRONT DISK BRAKE CALIPERS
REMANUFACTURED MASTER CYLINDER
NEW RE-ROUTED BRAKE LINES IN FRONT AS PER NHRA RULES
HURST ROLL CONTROL SOLENOID
NEW BRAKES FRONT AND REAR
NEW FRONT FIBERGLASS BUMPER
FIBERLASS REAR BUMPER
RICHMOND GEAR 4.56 REAR GEARS
ADJUSTABLE PINION SNUBBER
TURBO ACTION CHEATAH SHIFTER WITH COMMAND CENTER
NEW SHIFTER CABLE
PLASTIC LIGHTWEIGHT FRONT DRIVER SEAT AND CUSHION
FIBERGLASS FRONT FENDERS
FIBERGLASS LIFT OFF 6-PAK STYLE HOOD WITH NEW HOOD PINS
SUMMIT PRO-STAR KNOCK OFF FRONT WHEELS WITH NEW LUG NUTS
MOROSO 25x4.5x15 DS-2 FRONT TIRES
HOOSIER 30X9 RADIAL SLICKS – USED BUT STILL LIFE LEFT ON THEM
8 GALLON FUEL CELL
HOLLEY BLUE ELECTRIC FUEL PUMP, REGULATOR AND FRAM FILTER
ALL NEW -08 BRAIDED FUEL LINE
EXTRA FRONT WINDSHIELD – TINTED
REPLACEMENT CUSTOM DASH FRAME WITH GAUGES TO REPLACE ORIGINAL
ONE THAT WAS CUT UP. NEEDS TO BE INSTALLED
8-POINT ROLL CAGE
FRAME CONNECTORS THAT ARE BOLTED AND WELDED TO THE SUBFRAMES
TRUNK PAINTED WITH THE GRAY/WHITE SPLATTER PAINT FROM EASTWOOD
BLACK CARPET
GRANT 11 ½” STEERING WHEEL
MSD 6AL IGNITION BOX, MSD 2-STEP AND MSD BLASTER 3 COIL
MOROSO ELECTRIC WATER PUMP DRIVE SETUP
AUTOMETER 8,000 RPM SPORT COMP MONTSER TACH W/SHIFT LIGHT
PLASTIC RADIATOR OVERFLOW CATCH CAN (SUM-G1478)
CARBURATOR THROTTLE CABLE BRACKET (SUM-G1419)
26” RADIATOR WITH 17” ELECTRIC FAN
OTHER PARTS INCLUDED:
SMALL BLOCK ALTERNATOR BRACKETS, MOROSO ALUMINUM CRANK PULLEY, SPOOL TYPE TRANS MOUNT.
I AM ASKING $4950 FOR THE CAR AS A ROLLER AND CAN GET IT DELIVERED WITHIN A REASONABLE DISTANCE FROM EDISON, NJ FOR THE PRICE OF GAS, TOLLS AND TIME.
MY CARDIOLOGIST TOLD ME THAT I SHOULDN’T BE DOING THESE PROJECTS ANYMORE FOR HEALTH REASONS SO I HAVE TO SELL THIS CAR BEFORE IT’S COMPLETED.
KEN
EDISON, NJ 08820
Does the car have a drive shaft or headers and what shape are the quarter panels I was going to pm you but i can't find the option
Click on my screen name then click on Start a conversation.
The driveshaft was a stock unit with the smaller 7260 U-joint so that's gone. The headers were rusted from sitting, plus they were street headers. The quarter panel are in excellent shape and it looks like they were replaced at some point.
Ken
