[FOR SALE] 1974 Plymouth Duster-with title
Frogurt-NM
Santa Fe, NM
Rating - 0%
0   0   0
Looking for a car that has lots of the hard work done for you.
This is the car for you!
This car was a strip only car running low 12s when I purchased it in Nov. 2005. It has a 416 cu stroker motor with five 1/4 mile passes on it. Since then it has basically sat in my garage or someone else's garage while I was making modification to the car. The original owner spent his money on the motor and transmission. I have spent my dollars on everything else for the car.
Quick summary of what I have done; installed 12 point roll cage, widen the rear wheel wells, install complete CalTrac mono leaf system, installed new fast ratio Flaming Rivers steering box, scraped 80% of all undercoating off car, then had body work done by a professional body man (except for fenders and hood- planned on putting fiberglass parts); took down to metal around windows, doors, and trunk area then painted a (Zircon blue with clear coat), had front frame reinforced with welded steel plates. Doors are in storage, but ready for final paint. I have receipts for everything I did to the car. I can provide a pdf or excel document that depicts what I did and what the original owner did.
OR see more details on my website here:
http://buyanewcar-iraq.com/classic-cars-for-sale/
Currently the two of us have invested over 18k. I would like to get 10k for the car. Car weighed in at 3038 lbs. in 2005. Fenders where full of bondo along with the hood. I'm guessing it weighs about 2800 lbs now.
-David
