Chuckles1980
What would the exhaust manifold casting numbers be on a 1975 duster 360 with a 4 barrel.
Is this information in a book or a website somewhereWhat would the exhaust manifold casting numbers be on a 1975 duster 360 with a 4 barrel.
I actually can't find the creek casting numbers for a 75 360. According to what I looked up 74 on back is differentHave you considered googling those casting numbers to see what pops up? That would be a way for you to some double checking now that someone has kicked things off.
some people say they are some people say they're not. I went to a lot of mopar shows Last Summer and every 360 duster I've seen was either not original or was a 74 so I have no way of knowingHas anyone ever seen 340 manifolds on a 360 (from the factory)??? I've never heard of 360 engines fitted with 340 manifolds (from the factory). I know they will work. Is there any documentation on this issue?? Inquiring minds want to know.
treblig
treblig
Yea, a "bell" means 1 5/8" exit hole. The 340 has a flat flange.75 has a bell flange on the drivers side as well. At least on my factory original car with 40,000 original miles. The. NUmbers are hidden behind the heat stove. My car also has the smog pipe crossing over at the back of each manifold Mine came with a smog pump. Mine is a Canadian built car. Kim
I was referring to A body cars but then again....I've never had a good look at a Lil Red Express motor??? Are there any others you can think of??Lil Red Express?
treblig
TRUE!!No, but then you know how Chrysler was back then. They used everything up they could, so it wouldn't surprise me to see 340 manifolds on somethin they weren't supposed to be on.
Yes. These books are invaluable. Mega Parts USA - Reproduction, NOS and Used Mopar Muscle Car PartsIs this information in a book or a website somewhere
