[FOR SALE] 1975 Fury Station Wagon
MrBelvedere2
Sacramento, CA
I know its not an A body but thought i would post it here in case anyone might want it. I just have too many projects right now and this one should go....
1975 Plymouth Gan Fury 9 passenger station wagon. Last year for no smog check in california.
Original 400 big block/727 automatic. runs/shifts good.
power disc brakes, drum rear brakes.
power windows
It runs/drives/stops just fine. here is a list of little stuff it needs to be full daily driver. ...
has a champion radiator in it with shroud zip tied as a mount.(hits fan)
back window does not roll down, found a motor for it but havent installed
gas filler neck mount missing, just flops around currently.
passenger side rear door doesnt go down.
valve cover gaskets leak oil onto manifolds, havent had time to fix it.
Located in Sacramento, California area
clean CA title in my name.
I encourage seeing it in person, has some rust spots.
$3500 obo
can take more pics if seriously interested. thank you!
$2850 cash. Would like photos of the underside and that's all I need. Floors from the bottom And the sub frame
Hi Josh,
Thanks for the offer, but I can't go that low on it. I can send you the pics if you are willing to come up more on price. It's solid underneath
