[SOLD] 1976 D100 SWB
go-fish
Okla.
1976 Dodge D100 Adventurer Sport, 318 cid auto 2wd short bed w/ ~64,000 original miles.
New parts: radiator, p/s gearbox, p/s pump, p/s supply and return hoses, dual exhaust pipes/mufflers, Edelbrock AVS2 carb, MSD plug wires, dis. cap and rotor, spark plugs, fuel pump, and belts.
This truck is near rust free. The only rust to speak of is at the front of the bed floor at the seem, it's minimal. All the typical D100 rust spots are solid, like above the windshield, floor, and rockers. That is owed to the fact that this truck was fleet maintained and performed service in the CalTrans fleet in the SoCal inland areas. CalTrans is California's Dept. of Transportation.
San Diego, CA
$6,000 firm.
I have brand new van (B series) lower control arms that will come with it. Adding van LCA’s lowers the D100’s 1.5” in front and you can do a rear axle flip to even out the rear. This doesn’t slam the truck like a low rider but gives it a nice sporty stance while maintaining good geometry. The van LCA’s have a recess where the spring sits on it. Common modification with these.
Has a factory sway bar.
Clean title.
Pic shows top side of bed and underneath. This is where the rust is. It’s not rusted through. Pretty much scale.
The lower control arms are not installed but they are van, B100 arms. Installing those lowers the truck 1.5” in front and doing an axle flip in the rear will level it.
Pretty solid everywhere besides the bed. Someone has painted the valve covers blue, not Chrysler blue. Yuck.
Dash has no cracks.
