[FOR SALE] 1976 plymouth duster
was it a slant six car i need the air cleaner wing nut and the dip stick
Is the passenger side panel between door an rear wheel solid ? And would you consider cutting this section out to sell ? Understand if you dont , I need outer shell of panel only nothing behind it
ok thanks and just letting you know there are spot welds on the flat area on bottom side not counting the pinch weld
i could use the oil dip stick air cleaner wing nut coil with coil nuts
I am looking for the antenna cable (the one from the antenna mast to the radio). I also need the inside hood release cable. Do you have either?
I am needing the inside hood release cable. Do you have and how much? I am also looking for the radio antenna cable
