Prine
A-Body Fanatic
1978 Dodge D150 - Located in 88101, Clovis,NM
400ci bigblock, 727, 9.25" 3.21 ratio
Optima Red Top new in 2010
Radiator new in 2009
New Edelbrock 1406 600 cfm carb -2011
New Fuel Pump -2011
New Sending Unit -2011
New Brake Booster -2011
New F/R Brake Pads/Shoes -2011
New Belts -2011
New Dist. Cap, Rotor, plugs, wires -2011
New Air Filter -2011
Rear Diff. Serviced -2011
Good Windshield
Good Glass
Clean Interior
Factory Maroon Paint, was faded so bad and original bed damaged...removed damaged bed, put on solid tan bed....couldnt stand 2 tone....painted it satin black Feb. 2011.
Runs great, Shifts Great, Stops Great, Steers Straight.
Tires are 50% except for pass. rear....30%.
Will pretty much go anywhere, haul anything.
THE BAD:
AC Compressor Was Omitted...so NO AC or Components.
Truck has a crappy exhaust system, and exhaust leaks.
Driverside Window regulator is stripped at the bottom and top
Power Steering pump has a small leak
Valvecover gaskets are leaking a little
Clear NM Title in my name.....I drive it 4-5 times a week back and forth to work.
Selling so I can finish my 74 Duster 360 car.
$2500 AS IS or $3000 with new 2.5" FlowMaster Dual Exhaust System installed and Exhaust Leaks Fixed.
The simple truth is:
Old vehicles are simple, simple vehicles are cheap to fix, easy to maintain, and worth their weight in gold. The days of finding a good running $500 vehicle are long past.
PM me for more current pics.. and details....
Truck now has a rear step bumper and the windows are tinted.
Prine
New Fuel Pump -2011
New Belts -2011
Good Windshield
Good Glass
Clean Interior
THE BAD:
Prine
