Is that the type with the glass fuses or the blade fuses. I hae a block from an 80 Cordoba that I was hoping to transplant into a 65 wiring harness but can't seem to get the old connectors out.
Any fuse block block I beileve from '75 and up will swap, though you'll have to pay attention to exactly what wire is which if there not exact. This is an easy thing if you have the wiring diagrams in front of you, theres not alot of change.
Thanks for the responses guys... I must clarify..I need the schematic for the fuse block...I'm trying to fugure out the fuse for my doem light(which does not work) Yes they are the old glass type.
