Donny DartO
Active Member
cool. I just picked up the 904 yesterday, now I just need the right mounts.
The part throttle kickdown is an excellent change to the valve bodies. Keeps us from going to WOT to get a downshift at lower speeds!Generally '68 and up for the larger crank register. '72 and up I *believe* was for the part-throttle kickdown valvebody.
I could take some, I'm not at home right now, but the weight I saw was on the side behind the gear teeth.Some converters have weights. The "Balance" 340/360 cast crank weights are on the front of the converter. Do you have pictures?
oh awesome, I thought I was back where I started needing another torque converter.Don't worry about that one. That is to neutral balance the Torque converter.
even if it was from a 360 and had the 360 balance weight on it you'd only have to cut/grind it off to use it with a 318.oh awesome, I thought I was back where I started needing another torque converter.
Hi, where do you find the crankshaft hub register adapters? I have a 73 318 in a 64 dart that had a 273. I made a temp adapter but am looking for a real replacement. The previous owner did the work and I had a vibe traced back to the tq converter hub being smaller than the crankshaft opening. ThanksOkaaay... first things first. What are you starting with, a V8 or slant 6 car? If it's originally a slant 6, you'll need a different transmission. It will NOT bolt up. If it's a 273/318 car, you will need to find an early style torque convertor in order to use your existing transmission (the early TCs are different from the '68 and later 904s and do not interchange). Then you will need a crankshaft hub register adapter to fit the nose of the early convertor into your late 318 crankshaft.
A quick search:Hi, where do you find the crankshaft hub register adapters? I have a 73 318 in a 64 dart that had a 273. I made a temp adapter but am looking for a real replacement. The previous owner did the work and I had a vibe traced back to the tq converter hub being smaller than the crankshaft opening. Thanks
