[SOLD] 1982 Chrysler Cordoba LS
chryslerfat
Monroe,Michigan
This is a clean car that lived down south till recently. It has a fresh tune and rebuilt carburetor. Starts easy and runs good. You can hardly hear it running. Drives good down the road and has brand new tires. The only rust through I see is the bottom of the drivers rear 1/4 panel. 225 six and auto that is missing the A/C compressor but lines are intact so probably could work with a compressor. Not perfect and needs things fixed but is in good driver condition right now. Price is 2,000 Dollars and is in Monroe Michigan
If its still listed in two weeks when I'm back home I may PM you. Its just about 120 gallons of gas to get it home to the PNW.
Somewhere in my black hole of a garage I have one of the Direct Connection 225 stroker cranks that with a 0.40" over bore gives 245 Ci. You can over bore most \6 0.100" and some 0.120"
