swing69
fightin' socialism
My 84 318 block is cracked. I want to swap the entire 84 rotating assembly into the earlier block.
I understand the #3 bearing changed at the thrust bearing area, but I'm not clear as to how.
Can I make this crank swap? will the crank work? what do I need to do?
I also want to use the earlier 273 balancer, as this is going into a 1965 vehicle with right side timing marks.
thanks.......
thanks.......
