100% bondo and rust free never wrecked or repaired 1985 Dodge D150 Royal SE Prospector Short bed , 1 Family owned since 1987 , Completely rebuilt 85' 318 block , hv oil pump , 69' 340x heads with new 2.02 - 1.60 valves , springs , retainers and seals , .288/.444 cam , Nice lope to it , Edelbrock intake and Edelbrock 600 carb , All new main and rod bearings , New double roller timing set , New fuel pump , All ARP bolts , Headers , 2 1/2" pipe to H-pipe and super 10's dumped under the bed , FBO digital electronic ignition , Taylor 8mm race wires , Taylor cap and rotor , Valvoline Full synthetic oil , Completely rebuilt A904 Auto trans with shift kit by Chet-n-Micks performance transmissions in NPR , Fla. (Shifts good and firm) , 8 1/4 3.73 Mopar gear rear with all new seals bearings and fluids - less than 5500 miles on complete drivetrain , New shocks all around , 15x8's with new 275/60's and 245/70 Firestone Firehawks - less than 3500 miles on them , Lowered 2" in the rear using a Summit shackle drop , Rear roll pan , New tail lights , everything works and it is a very strong running truck , Miles will go up as I drive it everyday , $5500 as pictured , $5000 with stock steelies and good matched set of goodyears , I will look at trade offers with cash but be realistic please and they must be driveable , Clean and clear TN. title in my name , The truck is a 100% get in and go daily driver as is . It has a small crack in the lower left corner of the windshield that's been there for 18 years , the seat bottom has a few rips in it but not that bad , It is 30 years old so its not a showcar but a nice clean fun everyday driver.
Just claybar stripped , waxed and sealed today 5/27 , Also comes with a HOT ROD FLATZ Vintage Burgundy Metallic Gallon paint Kit that makes 1 1/2 gallons of sprayable material = $240 on ebay , Its located in Limestone Tn , 37681
