1985 dodge 8-1/4 rear end
FABO Welcome Wagon
  1. dazedand confused
    dazedand confused Well-Known Member
    155
    35
    Oct 3, 2010
    hollister mo.
    Local Time:
    4:23 PM
    Need some help? Rebuilding my 8-1/4 rear end with sure grip . My Hayens manual does not show torque spec for the differential cross pin bolt? and do I use red loctite or blue on the threads?and is the torque in inches or lbs? I think inches cant be very much?
  2. ScampMike
    ScampMike Despicable Damn Yankee
    34,057
    8896
    Oct 26, 2015
    all Mopar driveway
    Local Time:
    5:23 PM
    I did some searching - can't find a spec for that either - the torque spec can be either in.-lbs or ft.-lbs - depends on which item you are torqueing -- 12in-lbs = 1 ft-lb.
    Chrysler Axles - Gear Setup Torque and Backlash Specs:
    Pinion Preload
    (New)
    Pinion Preload
    (Reused)
    Ring Gear
    Backlash
    Ring Gear
    Bolt Torque
    Carrier Bearing
    Cap Bolts
    Chrysler 7.25" 12 to 14 in-lbs. 6 to 7 in-lbs. .006" to .010" 55 ft-lbs. 50 ft-lbs.
    Chrysler 8" 12 to 15 in-lbs. 6 to 9 in-lbs. .006" to .010" 65 ft-lbs. 75 ft-lbs.
    Chrysler 8.25" 12 to 15 in-lbs. 6 to 8 in-lbs. .006" to .010" 55 ft-lbs. 60 ft-lbs.
    Chrysler 8.75" - 41 13 to 15 in-lbs. 6 to 8 in-lbs. .006" to .010" 55 ft-lbs. 90 ft-lbs.
    Chrysler 8.75" - 42 15 to 25 in-lbs. 7 to 10 in-lbs. .006" to .010" 55 ft-lbs. 90 ft-lbs.
    Chrysler 8.75" - 89 14 to 19 in-lbs. 6 to 9 in-lbs. .006" to .010" 55 ft-lbs. 90 ft-lbs.
    Chrysler 9.25" (Rear) 14 to 19 in-lbs. 6 to 9 in-lbs. .006" to .010" 65 ft-lbs. 75 ft-lbs.
    Chrysler 9.25" (Front) 15 to 25 in-lbs. 10 to 20 in-lbs. .005" to .007" 103 ft-lbs. 63 ft-lbs.
    Chrysler 10.5" 15 to 25 in-lbs. 8 to 11 in-lbs. .005" to .007" 175 ft-lbs. 120 ft-lbs.
    Chrysler 11.5" 20 to 30 in-lbs. 8 to 11 in-lbs. .005" to .007" 175 ft-lbs. 200 ft-lbs.
  3. ScampMike
    34,057
    8896
    Oct 26, 2015
    all Mopar driveway
    Local Time:
    5:23 PM
  4. dazedand confused
    155
    35
    Oct 3, 2010
    hollister mo.
    Local Time:
    4:23 PM
    Ok thanks Mike !
