19_Dart_68
Located in Oxford, PA. 1988 Dakota Sport. Being sold as a roller. Was set up with a 440 and 727.
8 1/4" rear with 3.91 gears and a Spartan Locker installed.
Comes with lots of extras...
Aluminum radiator w/fan
MSD 6 box, gauges,
10 gallon fuel cell and electric pump with enough pushloc hose to run to the engine bay.
Many new parts...Summit Racing trans cooler, Front brakes rotors, calipers, brake lines and wheel bearings. (The front brakes don't look new in the pics, but I assure you they are.)
New power rack and pinion, New Saginaw Type II pump with Big Block Mopar brackets ($220 ),
New tie rod ends. New rear brakes. New proportioning valve, master cylinder, and most lines replaced.
Brand New Moog Upper Control Arms with ball joints and bushings...ready to bolt on.
Much more that I am sure that I'm forgetting. Come look at it now while it is still on the lift!!
Front tires are shot, the rears are Firestone Firehawks, which I think are soft compound tires...they look pretty decent.
$2800
Serious inquiries only please. Facebook Marketplace is wearing me out.... "Is this still available?"
MSD 6 box, gauges,
$2800
