1990 360 engine, trying to retrofit it to use a mechanical fuel pump.
Kern Dog
Build your car to handle.
Granite Bay CA
Hey there. A couple months back, I bought this:
It is a 1990 360 from a van. It has a car oil pan and a few goodies already in place including the valve covers, Air Gap intake and this:
As you can see, water went through it, maybe due to a bad head gasket or cracked heads.
My question here is regarding the fuel pump. These EFI engines had the hole blocked off where the mechanical pump usually fits but I've heard that an aftermarket pump eccentric allows you to retain a traditional mechanical pump.
Who makes these things and who sells them?
Thanks....
Unfortunately I believe Hughes Engines is your only source for the cam extension and eccentric you need for the short nosed roller cam you’ve got …
Hughes Engines
Thanks....
The '89-'91 360 tk roller should be the same cam as the '85-'89 318 pass. car roller, which had a mechanical pump...take the block-off plate off & look inside, there may already be an eccentric in there, or a spacer which would be swapped out w/a factory eccentric.
Holy crap, that would be a nice score.
I like the simplicity of a basic mechanical pump.
Otherwise....
HUG 7013​
CAM SNOUT EXTENSION (SHORT SNOUT)
87-02 V6 & V8 EXTENDS LENGTH OF CAM SNOUT FOR FUEL PUMP ECCENTRIC
$37.50
87-02 V6 & V8 Extends Length Of Cam Snout For Fuel Pump Eccentric Most hydraulic roller-cammed small blocks have a short snout (nose) on the front of the cam because they are normally used with in-tank electric fuel pumps. If a mechanical fuel pump is to be used, this cam snout extension is required to provide a mounting for the fuel pump eccentric.(P/N 10003) Includes cam bolt, custom cam washer, snout extension and offset key.
woof. i'd say the water ingress is from there not being a carb on it... rarely do you get intake runners that funkalicious from a bad headgasket or cracked head/seat area.
we talked about this previously...
i'll echo what killer and 72 said: check what you've got cookin' first and if you do need the adapter hughes is the place to get it. for better or for worse.
I forgot about that thread!
The engine was thought to be an '89 but the casting date reads XX-XX-90. It is an LA series of course. I thought it was a flat tappet engine but it is not.
I had much of that story wrong.
Quoted from that thread of mine that you linked, authored by "Professor Fate":
Roller LAs (from the factory) all had long snout cams. Some passcar rollers (non-TBI, with feedback carbs- usually found in Fifth Avenues and the like) already had mechanical fuel pumps. The later '88-'91/'92 TBI motors (found in trucks and vans) used an electric fuel pump in the tank and did not have the mechanical pump, however they still retained the long nose cam. The timing cover either used a block-off plate or did not have the pump boss finish machined, and did not have an eccentric installed on the cam- there was a special deeper cam washer used to make up the difference in depth with the eccentric deleted. Use a standard LA cam bolt washer and the eccentric is a bolt-on; either remove the fuel pump block-off plate or finish opening up the fuel pump boss on the timing cover- depending which you have- and you're good to go (or swap covers if you don't feel like opening up the boss on the TBI cover).
Magnums all had short snout cams and need the Hughes adapter and a timing cover/water pump/accessory drive swap if you want to use a mechanical pump.
Side note: Don't try to use a Magnum cam in a roller LA- it will fit and run, but it's lobes are ground for the Magnum's 1.6:1 rocker ratio and there will be a resultant power loss when run with the LA's 1.5:1 rockers.
Conversely, a factory LA roller cam used in a Magnum can give a nice little low-cost power boost with the Mag's higher ratio rockers.
I am not impressed with the Hughes engine cam nose extension... It does not look robust when I used it, I had to modify it myself...
I would recommend getting a cam made with the longer nose for the mechanical pump...
[/URL]
The first time I discovered a roller 'teener on the job was a red '85 Dippy, the head gasket started leaking on #7, just past the warranty....not a ton of miles for the year on it either. Sam also had an '83 Cordoba, gold w/a brown top, all well maintained & garaged indoors.....one never knows.
Didn't read all the response, but my '89 roller 360 not only had the long cam snout, but it also had the fuel pump eccentric on it even though it was throttle body injected.
That's what My memory was faintly telling Me.......
I’ll echo the above. The La roller will have a long snout cam. The magnum series is when they went to a short snout. The change came with the magnum timing cover.
I found four of these in the shed….
It just needs a good cleaning to make me feel better.
I have seen no less than six 1990 360 roller cam engines WITH short snout cam. I have seen them with the eccentric in place as well. My guess is later or closer to end of LA production is when the changeover began to happen. Best thing to do is pop the block off loose and take a peek.
