68383GTS
I am selling a 1995 Dodge Dakota extended cab 139,000 miles.V6 magnum,cruise,air,power steering,tow hitch.The truck runs good and I was driving everyday to work.There are somethings that need repair...
1.Water pump started leaking a month ago.Now leaking pretty bad.
2.The overdrive quit working 1 1/2 year ago.But other than the overdrive not working the transmission works fine.I drove it to Pittsburg,PA to pick up my Formula S.
3.The ignition swith broke last month.So it has a push button switch for now.
4.Heat swith does not work.It has a toggle switch and the heat only blows on high.I was told there is a relay that needs changed to fix this problem.
The body is in pretty nice shape with really no rust.Good work truck or v8 project truck.I also have a fresh built 383 or rebuilt 318 that I will sell seperate.
5. A/C does not work
Asking $1200.00 or atleast $600.00 and trade.
Located in East Peoria,IL
Jim
Jim
