Excellent info/advise! I disconnected the vac line & I was able to move the valve lever but it was tight. I dont have a vac pump to check it. I see the correct "heater hose connector valve assy" on ebay & it says in the descrip "vacuum closes non-bypass heater valve" & that makes me wonder if it is open right now & the problem is elsewhere but I will likely go ahead & spring for it since my working on it sprung a slight leak and if it is a problem elsewhere at least I should be able to move the lever between on/off much easier & & maybe wire it open in the winter & closed in the summer but I don't know, that will still not be addressing the problem IF it is open right now. right now the horizontle lever is toward the rear if that tells you if it is open or closed right now please check if you can. thank you for hipping me to the dog house being the likely culprit on the leaking cold air. I will specifically check it closely. thanks again guys I appreciate the comprehensive help, I am freezing!. RR
