As cast Trick Flow 190 heads with a 2.05 valve. Aiming for 550hp. Opinions?
Shouldn't you be able ootb make 550 hp with the right cam ?As cast Trick Flow 190 heads with a 2.05 valve. Aiming for 550hp. Opinions?
I think so. Just asking to see if guys think whether it's worth it or not.Shouldn't you be able ootb make 550 hp with the right cam ?
I'm pretty sure one of the other member that does heads said the valve seat won't go 2.05 hopefully he chimes in. Think it was pittsburghracerI think so. Just asking to see if guys think whether it's worth it or not.
But isn't that for a "maxed out" combination. Solid roller, big single plane, hi compression?To me they should reach your goal as is, at the 2hp per cfm rule of thumb they should be good for 600+hp.
Depends but I'd say your generally correct, but I'd say an average street strip type build will do 1.8-1.9 hp per cfm so 540-570 hp with 10-11:1 cr, around 240 @ 0.050" cam etc...But isn't that for a "maxed out" combination. Solid roller, big single plane, hi compression?
The TF 190 head is CNC ported from the factory. 550 hp is within reach with a TF 190 as cast.As cast Trick Flow 190 heads with a 2.05 valve. Aiming for 550hp. Opinions?
Where can I find it?IMM just posted a dyno run of a SB stroker with TF heads. I think it was an RPM i take and the cam sounded mild. 538hp i think it was…
A cam in the 650 lift range and a single plane would get it to 550hp.Here's a 514 hp trick flow 408 just got to find 36hp
408-Inch Budget Mopar Stroker Makes Over 500 HP
You should make 550 with the right parts, I would leave the heads alone for that goal. If you are trying to stab a 230 @.050 hydraulic roller with an rpm intake than probably not, but a good single plane with a solid ft in the mid 250s @ .050 or better with .580 lift and you should be good.As cast Trick Flow 190 heads with a 2.05 valve. Aiming for 550hp. Opinions?
I'm going roller. Whether solid or hydraulic. I'm hoping the Trick Flow single plane will be re-released. I saw an Australian website claim they expect it in June. Hoping we get it here.You should make 550 with the right parts, I would leave the heads alone for that goal. If you are trying to stab a 230 @.050 hydraulic roller with an rpm intake than probably not, but a good single plane with a solid ft in the mid 250s @ .050 or better with .580 lift and you should be good.
One can only hope TF starts making that intake again. I have little hope for that.
I‘d run a SFT long before I ever ran a HR. I was done with hydraulic rollers in the mid 2000’s and I was a huge advocate for them before that.
If I remember right @pittsburghracer checked the trick flows out and the intake seat did not have enough meat to go over the 2.02 valve size without requiring seat replacments.
Rat , What made you give up on the Hyd Roller ?
@273 is correct to a degree. While he has a good point on how things generally go, I say No. It’s a CID thing, that’s all. But he’s on it! The rule of thumb is for a serious but still a nice powerful build that is still in the realm of streetable. While the cam shaft does get a little large for some people, it’s really not extreme. Of course, the smaller the engine the more challenging it becomes. So that right there can be the caveat to this all.But isn't that for a "maxed out" combination. Solid roller, big single plane, hi compression?
I suggest a solid roller for the rpm capability. Or a SFT.I'm going roller. Whether solid or hydraulic. I'm hoping the Trick Flow single plane will be re-released. I saw an Australian website claim they expect it in June. Hoping we get it here.
