2.02 or 2.05 Intake Valve?
The cost of the valves and the valve job ..even without a blend, it'll pick up power.
So....
Is it worth it?
I should clarify. Someone commented about getting the heads cnc ported. That's what I meant was out of the question.
Aren't all Trick Flows CNC ported?
I didn't know they offered an as cast version.
At least when I bought mine they only offered 3 version's,
All were CNC ported
Just different spring/retainer packages for whatever Cam type you are using.
All were CNC ported
Yes they are ALL cnc ported.
Yes sir! That’s the one. Anyone can reasonably duplicate this build slightly defined for the street by skipping the head porting and running a 11-1 compression ratio. The one thing that would be a big HP killer is not using a tunnel ram.
There’s enough head flow on the as cast Victor head to make some great power. 11-1 is easy 93 pump gas. The only single planes I’d use is the Super Victor ported or the Indy intake and probably have to pro ported. I’d make the Indy work.
At the magazines 376 CID, this can be closely matched via a 360 crank into an.030 - 340 for 372 cubes or punching out a 360 @ .070 over. That’s a lot but possible! Sonic check that 360!
Wooooooooo
