kkeith1986
What kind of adapter plate do I need to bolt a Holley 2300 to the stock slant six 2 barrel manifold
Try a Mr. Gasket #1937
Fits my my super six manifold just finepretty sure the #1937 adapter is made for the larger bolt pattern 2 barrels and won't fit the slant and 318 bolt pattern
Would the mister gasket #1937 work if you'd cut a 1bbl and weld a 2bbl plate in parallel with the motor?
