.......so I just shut up.lol.
That's gotta be a first.
any idea if you need to go though BluePrint to get new caps and rotors?After verifying my timing marks with a piston stop, I ordered a new "Pro Billet ready to run" Distributor from @Johnny Mac over at Blueprint. It's a step up from the original Distributor, with Blueprint's usual great service.
Do you have as much power as before? And a vacuum advance can advance the timing while cranking if it's plugged into constant vacuum; with the throttle closed. Off idle vacuum can do the same thing with the throttle slightly opened; just not as easily. I just always like to know the "why"..
