moturbopar
1 howards hydraulic flat tappet cam. Lobes are designed to take advantage of mopar .904 lifter.
Cam would be good for a blower or turbo. Will work well N/A also.
Specs are 226 at .050 intake and exhaust. .520 lift with 1.5 ratio rockers. Ground on a 114 lobe seperation with a 110 ic. Cam will have a mild lope and has a powerband of 1800 rpm to 5600 rpm.
New in container. $120
1 hydraulic flat tappet CAM. Lunati voodoo 256 Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/220
Gross Valve Lift (Int/Exh): .454/.475
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1000-5500
$120
Both are new.
LSA/ICL: 112/108
$120
Both are new.
