65_valiant
I'm looking to buy this vehicle, buddy of mine only wants 1000 for it. It drives and shifts just fine and makes a clunk/thud when you shift into reverse, but goes no where. Shifts through the forward gears just fine.
if he has engine breaking in manual low then the rear band is working. if the snap ring in 0/d direct broke and unloaded the clutch that would give no reverse.Those trans are notorious for reverse issues. Typically the 46RE has a weak reverse band and that is what breaks. My 98' just broke one of the snap rings that holds the clutches in place and wont go in reverse either. All fwd gears were great. Id say drive it-check all the fwd gears and ensure OD works. If that checks then see if you have engine braking as you downshift manually with OD off. If you do, its most likely a revers band. Ill be tearing into mine in about a week for a rebuild. Hope that helps
Floyd
