Dartfreak75
Restore it, Dont part it!
Yea they have taught me alot along with jada and alot of other members here!
Yea I remember the chat room back when I first joined. I had forgot about that what ever happened to it?yea they are good guy's. it's too bad the chat room is no longer. I remember back 2012 and 13 chatting with Asa, and 318wilrun was in the room. Rani, tony and a few others too.
used to go to the chat room a lot when I got home from work. It was fun. RRR would show up quite often as well. Funny, I don't remember you fishmens67 ????yea they are good guy's. it's too bad the chat room is no longer. I remember back 2012 and 13 chatting with Asa, and 318wilrun was in the room. Rani, tony and a few others too.
.Just a report on the drivers side header. I went out today and I hooked up the center link, installed the starter, tighten motor mount, hooked up kick down linkage, small adjustment to the tranny lines and tightened the header to the motor.
I just wanted to report I didn't have to ding anywhere, any place, plenty of clearance. I do have manual steering and brakes, 904 tranny.
well, I was going to pull the 4 plug wires on the passenger side as well..
Your motor will be constipated on the passanger side by the stock manifold competing against the ds header.
What are those for ?Hey big news the postman rang once.
Got my Chinese stainless steel zip ties.
his roll of toilet paperWhat are those for ?
.his roll of toilet paper
Oh damn so you building a turbo engine?.
With an s. Rolls
They are for the end of the turbo pipe to hold the heat wrap from coming loose.
.Oh damn so you building a turbo engine?
twin turbos.... two leaf blowers mounted between the grill and radiator supports. Then a bottle of 104+ octane booster...… I'm toast!you building a turbo engine?
Oh dang sorry lol I want to try one of those Ebay turbo kits myself. I have read and watched several videos about them. They can make decent power for the money. Obviously with limitations.
Why are you telling all my secrets?
That was highly classified information on a need-to-know basis. Now I've got to change my plans My secret is out.
Could put a 80mm turbo on that magnum that's going into that Lil Red. LOL... I've played with the turbo cars from Ma Mopar.... They are the only car I could drop a 1/2 second by spending 3 dollars at a pet store.... LOL.
LOL...….. This is back in the nineties, it was fun beating the 5.0 fox bodies with junk 4 door K-cars.....Must be a fast gerbil.
Wow !!! Those look really tight. Nice work squeezing them in there. How does it sound?Ok, I report the good with the bad, the truth as it is. The passenger side was worse to install than the drivers side Yes, that's right!
I thought I was going to have to pull the torsion bar. I figured out the puzzle. I raised the motor equally about 3 inches. that got the header past the torsion bar. then I let the engine down, and raised only the passenger side to get the header on the studs. I like using the studs on the ends, that way I don't have to drain the coolant to change a gasket. Here are some pictures on how close the header is to the body.
yeah, passenger side was more of a challenge with these headers. Haven't started it yet, gotta hook up the collectors...Wow !!! Those look really tight. Nice work squeezing them in there. How does it sound?
