Welcome to the race Dan.
Thanks! Edit coming, caught cheatin' already, LOLWelcome to the race Dan.
And thanks for taking the time to do this!Welcome to the race Dan.
yes, it worked! Cool!! What link is that, onedrive??Added info to first post tell me if you can access.
Is a Poly considered a small block?Question... if your car is a factory 318 4 barrel, do you still get the .4 penalty?
that was gonna be my next question... Ma Mopar did...Is a Poly considered a small block?
It is an Athat was gonna be my next question... Ma Mopar did...
dizzy in the back? it's a small blockIs a Poly considered a small block?
So does a 392 Hemi. LOLdizzy in the back? it's a small block
cool! I didn't try it.Also on the worksheet if you plug in the + or - .2 etc it will autosum at the bottom.
you scared my fat little 318 poly gonna win? Hell, its in a 4 door b body, i spotting you all 900 pounds.So does a 392 Hemi. LOL
you spot us NOTHING!!!!!! You'll get to ADD to YOUR ET for the EXTRA weight …you scared my fat little 318 poly gonna win? Hell, its in a 4 door b body, i spotting you all 900 pounds.
Yes on the hit for 4bbl.
The poly is welcome.
so im a tad confused. So lets say the car runs 17.0 (random number), if it weighs more, it says add .1 per 100 pounds right? so wouldn't that make it 17.9? I probably have this backwardsyou spot us NOTHING!!!!!! You'll get to ADD to YOUR ET for the EXTRA weight …
I think all cars start with the nominal car, 318 2bb, 904, 2.76, 3300 lbs (without driver) at 15.9. If your car weighs 4200 lbs you would add .9 to the 15.9 for the weight putting you at 16.8 if all else was equal.so im a tad confused. So lets say the car runs 17.0 (random number), if it weighs more, it says add .1 per 100 pounds right? so wouldn't that make it 17.9? I probably have this backwards
ok, so the goal would be to run that time, or beat that time? Highest ET win? or Lowest ET win?I think all cars start with the nominal car, 318 2bb, 904, 2.76, 3300 lbs (without driver) at 15.9. If your car weighs 4200 lbs you would add .9 to the 15.9 for the weight putting you at 16.8 if all else was equal.
goal is to go as fast as you can. IF your "dial index" was 16.8, then if you ran a 16.5, you'd be 3 tenths faster than your index. But, you have to go through the entire penalty box, adding or subtracting from your ET (starting with 15.9) for each item. Pretty easy. So you might add for your weight, but have to subtract for a 4bbl, subtract for 3.23 gears, but add again for a 727 tranny. just an exampleok, so the goal would be to run that time, or beat that time? Highest ET win? or Lowest ET win?
