[Found!] 225 /6 throttle cable bracket
Cars and Mopar Parts Wanted
Thread Status:
  1. Tduff01
    Tduff01 Well-Known Member
    116
    2
    Jun 3, 2014
    Brookville, Indiana
    Local Time:
    8:31 AM
    Contact Seller
    I'm looking for a correct throttle cable bracket for my 225 slant. Whatever is one this on someone has poorly made the one on here now. Lol. It is in a 1972 duster.
    Thank you.
  2. whitepunkonnitro
    whitepunkonnitro Well-Known Member
    14,799
    935
    Dec 6, 2011
    Murfreesboro Tn
    Local Time:
    8:31 AM
    Is it the stock single barrel carb?
  3. Tduff01
    116
    2
    Jun 3, 2014
    Brookville, Indiana
    Local Time:
    8:31 AM
    Yes. Stock intake, exhaust, and single barrel holly. The one there now is just really crappy. But it has 2 bolts that hold it on there at the end of the intake / exhaust manifolds.
  4. Jorge Ramirez
    Jorge Ramirez Well-Known Member
    90
    7
    Jan 10, 2017
    Anaheim CA
    Local Time:
    6:31 AM
    I have a whole kick down set up if you and braket
    • Like Like x 1
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      Do you have any pictures of the bracket?
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      . Yeah I'll take picture when I get home I'll send you pictures of what I have. I'm working right now. So after work I'll send them
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      Can you send me a picture of the setup you have right now
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      Yea I will take a couple and send them tonight when I get home.
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      It won't let me up load here. I need to send it in a message I think. But your inbox is full.
      And I think what I have is just something someone made at one point.
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      Oh dam hahaha ok ok sorry man I got home last night really late I work untill 3am but I get out earlier today so I'll should be able to get them pictures won't let you down
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      No problem. Thanks.
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      They have surface rust but I'ma clean them and treat it and probably spray them down with temp spray paint
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      Sorry for shitty picture angles I'm taking this at 3am hahaha
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      It's ok lol. And I'm just trying to picture how it hooks up and everything lol.
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      Here is what I was talking about, someone rigged this up haha.
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      Yesh it looks right the thing he did probably is weld it since he didn't have the other exhaust manifold bolt that goes on the right side.
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      So it's the right brackets but they added the top section because they didn't want to do it right lmao.
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      Yeah dude pretty much that set up you have I was looking for three years and it's cool because you even got the kick down witch took me forever to find but I mean I also just have the bottom braket too if you need it man apart from the ones I showed you. I don't need them since I went to a two barrel Ibtake
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      I would like to make it look cleaner and nicer without that crappy welding job lol. Does the normal bracket you have go to the same 2 studs it's on now? Or is it supposed to be elsewhere?
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      The braket originally goes bolted onto the bottom of the the two bolts that hold the manifold s together so it would look a lot cleaner. And we're the weld is made would be fine and the top brajet. Don't k ow if he out that plate there because of the later egr stuff butt probably and even then you can get a cleaner looking ate to from eBay that is meant for that block of plate
    • Tduff01
      116
      2
      Jun 3, 2014
      Brookville, Indiana
      Local Time:
      8:31 AM
      You wouldn't happen to have a picture of how it's supposed to go would you? From look at it seems like your pictured bracket would be sandwiched between the 2 manifolds?
    • Jorge Ramirez
      90
      7
      Jan 10, 2017
      Anaheim CA
      Local Time:
      6:31 AM
      Hahaha no it goes at the bottom but yeah I'll try since I swapped out the one barrel for the super six set up I'll see if I can find the bts to show you on my old one barrel manifold set up. But the braket goes all the way at the bottom and it's held by two nuts at the end of the two bolts that hold the I take and exhaust manifold together.
    Thread Status:
