circlepilot
Just a FYI. I would have used hardened washers under the head bolts. When you mill the head the bolt threads go deeper into the block. By using washers, the threads are closer to the original depth. Also the washers help to get more consistant head clamping.
I wondered about that. If I was to do that...wouldn't that compromise the integrity of the crush on the gasket, Even if I replace them one at a time? That's an expensive head gasket from Australia.
Norm
