concrete52
Active Member
has me a 75 dart swinger - automatic - possibly going to the a833 - looking at rebuilding the engine - getting the good quality parts first then going to the machine shop for some machine work - its a driver fellas - looking at the comp cam 64-240-4 - .020 0versize pistons cause needs cylinder wall boreing - milling the heads a bit - block to head match? - crankshaft polishing - 3 angle grind on the valves - this is as far as i am now - can you fellas recomend other things that i should follow up on as far as machine work goes - and good quality parts for the rebuild - thanks
