jeffrey356
I have a 1965 dodge dart w/ slant6. I've stumbled onto info that there was a hyper-pak package for '60's 225 ci. I'm interested in buying the complete package. If not, I have approximate specifications for parts needed. Long runner intake manifold, Holley 4bbl 4160 series w/390cfm or Carter AFB 3083f 4bbl, mechanical cam (Clifford) w/ 276 degrees duration & .464 lift and .010 intake & .020 exhaust , 1.70" intake valves and 1.44" exhaust valves both are stainless, valve springs damper installed ht. 1.67/1.70, wire dia .206 w/ lift range .430/.500", Clifford split headers w/ dual 2 1/4" pipes. I can't seem to find parts. jeffrey356.
