When I first got my 68 dart it 235/60/14 on all 4 corners. They were mounted on stock
5 1/2" rims. I did have a small rub on the front fender while turning.
I tried these 235/60-14s on 7" Mag 500s on my Barracuda and it wasn't even close to fitting in the front. I wouldn't thing a Swinger would be much different. Sorry if the Cougar is causing damage to anyones eyes.
I think you'll be close on front. Have you test fit the wheel on front? The rim of the wheel will probably be very close to the upper control arm and the tie rod end. Double check there. You might have to crank up the torsion bars to keep the tires from hitting the fender lips on tight turns. The back tires might be a bit close to the springs but I think you should be okay there.
