273 Commando
mooser's dad
Well the kid finally did it, he lost it and smacked the curb so hard he folded the front left wheel. While I'll be in possession of the Moose Mobile (74 Duster w/ 273 Commando) for a while fixing it, I thought of doing up a spare 1973 318 I have laying around. The 1965 273 Commando that's in the car has a bad head gasket and there's water in the oil. So here's my question...I have 2 good motors to work with, but I want to rebuild the 318 block with a budget Summit complete engine kit with pistons. Should I/can I use the steel crank and floating rods from the 273? And should I use the closed chamber 273 heads? I can take the adjustable valve gear and the fairly new Comp 270S solid cam (224 @.050, .468 lift) and roller chain set from the 273 also. The 273 has an Eddy Performer intake, Carter 625 Comp AFB, Heddman Headers, re-curved factory electronic ignition, so the right bolt ons are already present and working well. I think more inches on a budget would be the ticket. And yes, he's gotten the reprimand and lecture to go with it!!
The other option is just build the 318 as is with a mild hydraulic cam and buy a new chain set too. Cam selection is welcome here. CR projected to be 9-1, gear ratio is 3.21 with a 904 and stock converter.
