[WANTED] 273 4 barrel aftermarket intake manifold
What is the difference between the 64/66 and the later one?
I’m looking also (my car is a 64)
The difference between 64/65 and later 273 is the center bolt angle of the intake going into the heads. If your 64 has later heads than you can use a different intake. Some guys just wallow out the holes and make the intake fit.
Ok, thank you. Is it just the center bolts or all of them that are different angles?
I believe all intake mount bolt holes are different. All depends on which heads you got. Pop a valve cover and check casting date?
I have a rare and nearly new Offy 5748 that was bolted up for break-in. It was designed specifically for the 64-65 heads.
PM me if you are interested. Cheers - Mike
