[FOR SALE] 273 block .030 1967 casting date
1966Post
Wisconsin
1967 casting dated code 273 block. .030 over and will build as such. I got this years ago as a long block as I wanted the 920 heads and rocker gear. It had a spun rod bearing so I parted the rods/pistons. Still have the steel crank put you better be desperate for one..... Block is free in central Wis for pickup.
Thanks FABO!0
