cudadan1
Member
235 hp how do I know if its the real deal or lets say the original motor that came with the car?
Thanks
Dan
:afro: know what im sayin?
Thanks
Dan
Maybe some info on the car this 273 is in would help.Check for serial #,s on the block.235 hp how do I know if its the real deal or lets say the original motor that came with the car?
Thanks
Dan
Pistons and cam can be changed too so finding them or not finding them means very little.The only way to verify a real commando motor is to check the pistons. The commando motors had 10.5:1 compression with with dome tops. Commandos also came with a more agressive camshaft. Everything else was the same and could be bolted to the 273 2 brl motor.
