Forged crank 340 counter weights are not bigger than forged crank 318"s. they are the same casting #, BUT, rod journal 1 / 2 and journal 7/8 have a lightning hole bored into them to reduce the weight. Pics 340 left 318 right.
I thought that was just a /6 thingThe only issue you will have is the pocket in the convertor flange for the nose of the convertor. In approximately 1968 they enlarged the diameter of the recess in the crank to accommodate a larger nose on the convertor. If you can find a '67 and earlier crank, it's a drop-in; if you find a '68 or later crank, it will require a spacer bushing to be pressed into the crank to let it match up to the '67 and earlier convertor.
Not a snow balls chance in hell that they are the same other than the same stroke. Kima 318 or a 340 crank are the same, casting numbers are same. both are steel cranks
YUP. To offset the heavier connecting rods of the 340.Forged crank 340 counter weights are not bigger than forged crank 318"s. they are the same casting #, BUT, rod journal 1 / 2 and journal 7/8 have a lightning hole bored into them to reduce the weight. Pics 340 left 318 right.
I have with the 273 commando engine that is matching numbers in my 67 formula S
Sorry to be that guy but....but am having zero luck as I would love to save the matching numbers engine
Period correctSorry to be that guy but....
There is nothing on the engine that ties it to the car except the engine build date being days to weeks before the car assy date.
Any 273 with a build date in the range will be undetectable as not being the OE engine. You will know but that is it
My 67 dart has the OE engine and was rebuilt once. But if it can't be bored again any engine built in the last quarter of 66 will work
Correct me if I am wrong but as far as I knew a 318-3 was a heavy duty truck motor and had a steel crank in it and fully floating rods as well as other strength parts.Hot Rod magazine built a cast crank 340 using the 318-3 cast crank years back, so the cast cranks can be interchanged. The reasoning was that the 318-3 crank was primarily a truck crank and was supposedly stronger.
Nothing is ever "exactly" the same regarding balance from one engine to another. It will be best to get the reciprocating assembly balanced when replacing the crankshaft. Something a quality engine build should have done anyway.So a guy could use a 318 crank and the 273 rods and domed pistons and it would be exactly the same?
This ^^^^^^ X 10,000.I just can't imagine pulling a motor apart, changing the crank and not rebalancing the engine, or for that matter having the whole thing refreshed while it's out. If it's decent miles you might have a fresh motor for the cost of bearings, rings and a hone. If nothing else the bearings are a lot better quality than in 1967.
but i saw this u-toob vidya where this guy said you can just mix n match all that stuff! it don matter tall!Nothing is ever "exactly" the same regarding balance from one engine to another. It will be best to get the reciprocating assembly balanced when replacing the crankshaft. Something a quality engine build should have done anyway.
Thanks Jeff, I think he knows but he also knows what it will cost to get it shipped half way across North America. Is there any way to know if the crank is forged or not without tearing the engine apart?64mopar64 has an entire 67 273 commando engine that i believe is partially tore down. give him a shout and see if he will sell you the crankshaft...goodluck and best regards
It's just a matter of removing the oil pan. If the crank has the small converter register, it's a forged 273 crank.Thanks Jeff, I think he knows but he also knows what it will cost to get it shipped half way across North America. Is there any way to know if the crank is forged or not without tearing the engine apart?
Cudamark, this is a quote from one of your old posts from back in 2012 about 273 cranks. @64mopar64 read along.It's just a matter of removing the oil pan. If the crank has the small converter register, it's a forged 273 crank.
I believe that 318-3 motors had forged cranks as did the first few years of LA 318s (red blocks).
