[SOLD] 273 from a 1964 Dodge Dart GT
Jimmy-James
Phoenix AZ
came with the car, pulled it and covered with a tarp. its easier to supercharge a 318 then a 273. have exhaust manifolds but not on motor and I need to take the oil filter adapter and the dist hold down for current motor.
located in West Phoenix AZ
Keep the steel crank.
You could use it for the super charged app.
318 were cast, strong, but not as strong as the steel version.
plus...your torque convertor is the small snout, early style and unless you have a new one made using a later case... there will be a mismatch of small snout / big crank register... may cause issues like vibration.
1968 was the change over, everything before will be small snout/19 spline as opposed to large /27 spline iirr.
Using the 64 trans right?
Keep the crank or buy a late case/early inerd convertor. Machinist should have known this..
318 were cast, strong, but not as strong as the steel versionplus...your torque convertor is the small snout, early style and unless you have a new one made using a later case... there will be a mismatch of small snout / big crank register... may cause issues like vibration.
Would you ship to LA?
