coffeedart67
Finally getting my 273 together, the fuel pump eccentric was grooved some, called all around and nobody has one. Should it be okay to use as is? Do they ever fail? Should the bolt be loctited? Looking through my gasket set I didn't see the fiber gasket for the right angle oil filter adapter? Is this something I can get at an auto parts store?
Thanks
Aaron
Thanks
Aaron
