273 is it good engine?
In November of 1972, I blew up the original 273 in my 65 Barracuda at 150K trying to make it home from Charleston, South Carolina to Cochran, Georgia in second gear after I broke the 3-4 shift fork. My ship was leaving for Nam right away, so didn't have time to fix the trans before trying to get my car home for the duration. While I was gone, Dad replaced the 273 with a 340. The 273 with 4-speed would keep up with SS396 Chevelles through first gear (3.09 low gear helped here), but they would pull away in second and keep pulling away. Never got beat by a Chevelle or GTO after swapping in the 340.
A 273 has the same stroke as a 340, with relatively heavy pistons, plus even the hi-po 273's were given a pretty rinky-dink cam. So, at least stock to stock, a 340 is more of a revver. You want to keep your 273 for whatever reason, fine with me. I actually liked my little 273, and they can be built to make good power. But a 340 has 67 more cubes than a 273, and at the same level of tune will make 60-70 more horsepower than a 273, and will have a much stronger low and mid-range. That's just a fact. (These days, of course, with the easy availability of cheap Chinese stroker cranks, even 340's and 360's are little motors.)
I went the other route. I bought a 72 340 Duster with about 50k on the speedo. I pulled the 1.88 intake valve 72 J heads, milled them .040, gasket matched them to a 71 340 Intake, pocket ported them, competition valve job, and Viton valve stem seals, and put them on my 64 273 shortblock with 10.5 TRW +.040 forged pistons, bored and honed with torque plates. I also took the used 72 340 cam, windage tray, and added a 71 340 4 speed TQ. I used the 273 drivers side exhaust manifold and a 72 340 passenger side manifold finishing with dual exhaust and turbo mufflers. All this in a 64 Barracuda 4 speed with an 8 3/4 rear. WOW! what a difference. That combination would freak people out. And It would get mid to high 20's mpg cruising on the highway.
