"Dart67"
I ran into this problem when I went to drive in the standard National PB 286 bronze pilot bushing.
I also tried using the Dakota National FC 69907 Pilot Bearing.
Neither one would work due to the crank register.
The crank is from a 1965 273 4bbl engine that "had" a 904 automatic bolted to it.
The pilot bushing hole in the crank is a unfinished bore and the large hole has a 45* chamfer instead of a square sholder for the dakota bearing to seat in. See photo below.
My solution was to measure the inside diameter of the large crank register hole which was 1.544".
Then chuck the dakota bearing up in my metal lathe and turn it to 1.549 so that when driven into the crank it will be a snug fit.
I also cut a small 45* chamfer on the back side of the bearing so that it would seat against the crank hub.
I drilled and tapped three 10 x 24 holes evenly spaced on the diameter of the bearing so that I can thread long machine screws into them to push the bearing from the hole in the future for replacement.
I then made a driver tool that will work for either the bronze busing orn the dakota bearing.
The tool is made from a scrape piece of 3/4" steel shaft and a 3/4"
washer welded square on the shaft.
Here is the modified bearing installed in the crank hub.
I used a little loctite blue around the outside diamter and the back side of the bearing when I tapped it in place.
Here is the how the bearing is removed from the hub. Tighten each screw a turn or two at at a time to push the bearing out.
Herb
Herb
