easyrider
65 droptop
I've read a lot about 318, 340 and 360 motors being stroked. Has anyone ever stroked a 273? I guess you could buy a 360 for less than it would cost to stroke one, right?
Tom
Tom
Yep! I think a 4" stroke would get you around 350 cubes. The pistons would be the hardest to come by. They would have to be custom made.
The Trans Am racers de-stroked 340's to 302's in 1970 and finished 4th.
They finished 2nd with a 273 Barracuda Formula S....
I didn't know that one. Pretty interesting...
318 with 45 more cubes made 50 more horsepower than the 273.
To be fair, in 70 they were running wide, heavy E-bodies against the other guys' pony cars. But the 273 is a great, well-balanced engine design -- it just doesn't scale up. The proof of that is the standard 318 -- more cubes with the same small valves and ports doesn't really do anything. But if you upgrade the heads, then you might as well go for a bigger bore, and so on.
A .03 over 273 with a 4" stroke is 336.67 cubes.
Standard bore = 3.63 = Diameter
3.63 + .03 = 3.66 overbore = Diameter
Radius = Diameter / 2
Radius = 3.66 / 2 = 1.83
(Radius**2) * pi * height = volume of a cylinder
(1.83**2) * pi * 4 = 42.0835
42.0822 * 8 cylinders = 336.6681
That is the way I do it. Something I learned in math class eons ago.
It varies a little depending how far out you take pi etc.
Ok, so im gonna tag along if I may and ask 273 head questions....
Im thinking future plans, but with Dads 67 cuda. Heads are stock with new Eddy springs.
New solid 270-s Eddy cam
New dbl roller timing chain.
Std bore block I believe and stock pistons.
New Eddy 600 carb
I am thinking of doing my own porting/polishing/gasket matching. Is there anything else that I can do to them, or would/should they have to be sent out to be machined??
Im planning on doing the port/polish/gasket match myself.
Ideas??
Oh yeah low budget too....I dont want to get into the lower end....yet..
Thanks
New Eddy 600 carb
Ideas??
Thanks
Have the heads been milled? Do they hardened exhaust seats? Have you done a valve job? What Intake are you running?
When? Compared to a 273/2 barrel maybe. The HP 273 was rated at 235 horse. The 318 of the same era was rated at 230 horse. The torque was rated the same @ 260
Ok, I musta had a brain fart again last night, the cam is not an Eddy it is Comp 270-s
We went with complete cam lifter springs, from Comp
springs are 901-16, cam is 270-s solid, timing chain dbl roller from Comp, the carb is eddy.
When we installed all the new goodies, we didnt measure the bore, but pretty sure its std bore 2bbl pistons
heads are stock from a commando engine, (not sure if there is a difference) and I dont think any work at all has been done to them other than new springs. I believe this engine has approx 50 thousand miles.
Intake is stock 4bbl iron commando intake. Im still thinking of going LD4B, but that intake has no provision to mount the coil.
904 with I believe 2800 stall. Not sure how to tell.
Im not looking to go crazy with it, but just stuff that I could do in my shop to make it a little "healthier"
Thanks
