That's a goodun! I tell you man, with a camshaft of that size, you need to contact Mike at @B3RE B3 Engines and let him walk you through how to properly locate your rocker shafts. You will NOT regret it. I tagged him so maybe he'll chime in, but if not, here's his web site with contact info there. I would consider it imperative that you do it. It's WELL worth the money!292/509
Don't get pushrods until you get your rocker shafts properly located. It's THAT important with a camshaft of that size.After I use a pushrod checker I will be using Mancini's cut to fit pushrods like PA Dodger advised seems like how can you go wrong with a kit like that ...thanks everyone for helping me solve this Mopar mystery tonight....
You will have great results! Mike is a legend genius! He fixed me up with my unicorn slant 6 head after I put the 318 valves in it. They are .300" longer than the slant 6 valves and required a good bit of correction for the rocker shaft location, so I have first hand experience with Mike's expertise. He's top notch.Will do triple R
You will NOT be disappointed!I've heard about his geometry correction kits and have been meaning to use something like that and finally get a well oiled machine type 340 that runs semi friction free
Thanks! She's a hoot to drive and the unicorn head motor ain't even in her yet! I'm assembling it now!With the way Vixen sounds I would put money on it that was a 273 with the hypo manifolds and the resonated barracuda tip...unreal raspy lil car...bet she's fun
I think you're definitely on the right track!I'm definitely figured out I'm going to get shafts from rocket that are thick hard chromoly steel with banana grooves
Sometimes you have to elongate the holes, if the correction is a lot. I had to do that on my slant 6.How much can the rocker shaft be moved before you have to mill the holes in the shaft?
I bet that's a runnin motor scooter! You got any videos of it? I'd love to hear it.I run 273 adj. rockers on my 340 with the 508" lift purple shaft cam. I am using crane cam adjusters on them with jamb nuts. My block has been milled for zero deck height and the heads have been milled slightly, I measured and used custom push rods from these guys: oepushrods.com
Probably someone was too cheap to buy new pushrods to use those rockers with hydraulic lifters, which are taller than solids. Spacing up the shafts gave enough clearance to run hydro's with the solid lifter pushrods. Seen this before...actually works, but not correct.But why are they there and what were they used for
