I have a 65 dart with slant six 170 3 on the tree. I want to drop in a 273 but want to use 3 on the tree still. Is this possible and if so what will I need to do?
For starters: V8 radiator; under hood ignition and starter wiring changes; different engine mounts; larger exhaust, possibly need larger fuel line from tank; carburetor linkage; and different bell housing as /6 and V8 have different bolt pattern.
Also you may want to consider up grading brakes, torsion bars, and depending on how built that 273 is a heaver rear end. Just dumping extra power in and not upgrading the suspension, drive train, and brakes is not a good practice.
