If I understand correctly, the 273 is an internally balanced engine. Am I correct to assume then, that the stock torque converter is unweighted? I ask because I'm going to be installing a 360 magnum into the car that has the weighted harmonic balancer and flex plate. Do I need to pull the converter and remove weights, or am I good to go?
