66Glassback
Active Member
I know right!
Hey everyone, just wanted to update you on the block. In the picture is where the oil filter housing mount goes. Someone drilled out the hole and epoxied a sleeve in it. That is where the oil in the coolant is coming from. I found a good 273 block that I am going to pick up tomorrow. Thanks for everyone's response (even all the quarreling... I kind of found it funny.) I will update with some more pictures later.
Where is the crack? Oil gallery pressure is higher than coolant while running but when you shut the engine off the oil pressure goes to nothing while the coolant has to cool off to drop pressure.I recently removed my 273 Commando engine out of my 1966 Barracuda. I wanted to have it checked out and rebuilt. It was getting a small amount of oil in the coolant but no coolant in the oil. Other than that it ran great. The machine shop I sent it to found a small crack in the block. I have found someone that has a 273 that I could purchase and use the block as a doner. I was wondering, seeing where I am at, should I just find a 318 or a 360 to rebuild and will one of those motors be ok to hook up the A833 4 speed transmission to?
There is no "numbers matching" until sometime in 68 for some models. Date code correct or casting date correct is all the closer you can get.Where is the crack? Oil gallery pressure is higher than coolant while running but when you shut the engine off the oil pressure goes to nothing while the coolant has to cool off to drop pressure.
Antifreeze will leak through where water will not.
That crack must be fairly small.
Another question is, is the engine numbers match to the chassis? If it is the engine that came in the car, I would seriously try to get it repaired. Numbers match are becoming scarser and more valuable.
That is an aftermarket shift handle for 67 up A-Body. If I remember correctly the whole shifter needs to come apart to remove the lever. Do you have a center console? I'll post a 64-65 original Hurst shifter tomorrow.I will be getting back to it Wednesday or so, I will update then. Thank you. As far as the weld goes, I have no idea.
