rigger3006
finally got it done this week, initial test drive i felt like i had castrated my best friend(72 demon), car still didnt start pulling until 3500, same as previous cam,slightly better bottom end, brought it home, lo and behold had a slight vac leak under carb, fixed that and swapped out 3.5 power valve to original 6.5 that came with 670 avenger. vacuum has doubled from 7 to 14 at about 700 rpm idle, right now initial is at 16, not sure about total yet, still working things out, second test drive was better, bog almost disappeared from off idle hard take off, now pulls hard from 3000, but unfortunately this thing starts crapping out at 5600, ive lost 1400 rpm on top end, not too impressed with that. cranking compression did not change whatsoever, still at 120, as was expected. combo is 85 318, ported 302s with 1.60 exhaust valves, ld340,670 avenger, 3000 hughes TC, 355 sure grip, 1 5/8 headers, still cant lay rubber off the line!
