[WANTED] 2bbl intake choke well
There were many differences between various engines . What is the exact application ? Type of carb and intake etc...
If you have a 2bbl Carter carburetor, these numbers may help you. Chrysler part number for the choke is 2951651. The Carter number is 170-222. Choke cup is #2951544 and cup gasket is #2951545. If no one here has these, then check eBay.
I have a cup and gasket from a 4-barrel application. Not sure if it's the same though.
