I learned pretty much the same. Lumpy bumpy cams sounds cool as heck but suck for street driving. I swapped the same cam you had in lieu of a 242/528 MPP solid and was much happier. It makes gobbs of tq at all rpms and idles nice and drives friendly in all situations.
Wait what?lol,
the 292/508 I measured at
[email protected] IIRC
I thought that cam had crap torque at the bottom end. But apparently I was wrong.
#1) I had installed that 292/108 at.............. 11.3Scr/8.76Dcr/176psi/
143VP
#2) The next cam 270/280/110 cam went in at 10.9Scr/8.92Dcr/184psi/
162VP
#3) the final cam,a 276/286/110 cam went in at 10.9Scr/8.72Dcr/179psi/
153VP
The first cam@143VP comparatively, wasn't that bad. The problem was that the power was all way up there in the rpm,and I could really feel the powerband kick-in; so the bottom end just felt real soft,in comparison.The real problem was the 3.55s I wanted to run.
The next cam #2, had no such power-surge, and the 162VP was awesome, but it had way more torque/VP than the car could handle. AND I did miss the topend rush some.
Enter #3, I gave up some VP, and got a reasonable top-end rush back.
All three cams burned right thru first gear, and most if not all the way thru second, sooooooooooo,I suppose I shouldda just fixed my 60ft................ sigh.
Your 242 @.050,(which IIRC is a 284adv) would still be way more power up top than I need, and the psi/VP would fall again to where I wasn't happy the first time.lol, to 10.9Scr/8.58Dcr/175psi/
148VP
Oh wait you said solid, so I don't have an advertised for that one, but the VP would probably be a little stronger... At 280* adv, and if I bumped the Scr back up I get......... 11.3Scr/9.0Dcr/187psi/
160VP, Hyup I could totally live with that. I guess I'd be on the hunt for 4.30s again,tho.
In all honesty tho, that little #2 cam,the 270/
[email protected] was awesome. I just bought a GVOD and started splitting gears, and never again felt the power-loss compared to the 292/108 . With a double overdrive, it returned incredible fuel economy.And with 8 useable gears, there was never a time I had to wait for power/torque. If it hadn't dropped two lobes right after an oil-change (that was when they took the ZDDP out), I woud never have changed it.
